My GE microwave (model JES145DNWW) stopped heating. Everything else seems to work. I pulled the cover and found a melted connector that is plugged into the circuit board where the main power cord hooks up to. I cut the wires from the melted connector and put new stacon terminal on them. It still didn’t work. There is a in depth trouble shooting guide inside the microwave but I’m not too sure about the hazards of working on it with the cover off. Is this a problem? And also if you could give me some idea what to check out it would greatly help me, since some of the symbols on the diagram are not too clear. I am an electrician, so I am familiar with how to use a meter, ohm for continuity, and read schemactics fairly good. Thanks for any help you can give me.
Related topics
GE Profile Microwave lost power | 5 | 3227 | February 10, 2012 | |
GE model JES1451BJ02 SENSOR MICROWAVE OVEN NOT HEATING | 1 | 3666 | October 26, 2010 | |
GE Microwave Not Heating | 9 | 2094 | February 7, 2018 | |
No heating | 1 | 1555 | September 15, 2008 | |
GE Microwave. Replaced fuse and won't ru | 4 | 3616 | August 2, 2012 |
