range elements won't stay hot cycle on and off
glass top range heating elements cycle on and off repeatedly but don’t really get that hot. Is there a problem with the limit switch?
Hi.
Please be more specific: Are all four elements acting up?
Thank you . Post the results.
Yes all four elements are cycling. They begin to cycle almost imediately.
Hi.
Check for 240v at the terminal block and tighten power cord contacts.
If the oven heating up good, then most likely you have all 4 burner switches go bad at the same time.
That is very untypical. Unless they went one by one.
I recommend you to replace one switch at the time and see if it will fix the problem.
You can return any unused parts even if they have been installed.
The left/rear and r/front infinite switch
[part]AP3046996[/part]
The right/rear infinite switch [part]AP3010400 [/part]
The l/front infinite switch [part]AP3030161 [/part]
Her are the breakdown diagrams and Replacement parts for Whirlpool RS696PXGQ2 RANGE | AppliancePartsPros.com
Good luck. Post the results.
