range hood exhaust fan blade
GE Model No: V320 003AD (ID plate is legible)
I’m looking for a replacement fan blade for this model range hood exhaust…
I tried a similar size blade from broan but that one slides down the shaft and rubs against the frame plus the pitch was less cutting cfms drastically… The old blade was made by tec air inc but a call into the company went unanswered… The tec air p/n is 406C51901…
My next move is to use an aftermarket motor/fan assy altogether but thought I would give the APpros a shot at finding a ge part number… Thanks, kooler
I am working on a thermador rang hood model PHE42US. They had an electrical surge and the control board was cooked. My question is how do you get into the board.
Call the customer service at 877-477-7278 and ask for Adam.
The water leaks from the hose connection on the resevior. the tank seems to be in good condtion. How do I tighten the hose fitting?
