Found a felt seal in my clothes dryer. Appears to be the rear drum seal. How do I replace it.
I have not worked on that model with that felt, but here is a service manual which will show you how to open up the dryer, and you should be able to see where it goes.
http://www.servicematters.com/maytag_library/docs/16026315.pdf
Good luck, let us know if you need more info
