Redd
Hello
My dryer will not get hot so I am pretty sure it needs a heating element. It was replaced about 1 year ago. My question: If your dryer will not shut off automatically can it burn up a heating element and if so what part would control the end cycle of a load of clothes. Is it possibly the dyrer thermal fuse, cycling thermostat, thermal cut-off, heating element wire or
wwwwwhhhhhhaaaaaaaatttttt!!! HHHHHHHeeeellllllppppppp Me Somebody.
Redd
Redd,
Does the timer moves? Would the dryer stop if you move the timer to the "off" position manually?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=118464&&model_id=265780
— Begin quote from Redd;111530
Yes, Gene. When drying clothes I have to manually put the dial on the off position or open the door to stop the cycle. Thanks Redd
Looks like the timer has gone bad. Do not rush with the heating element unless you’ve checked it for continuity and it reads "open". Might be a bad timer caused it not to heat as well.
[SIZE=6]Thanks Gene,[/SIZE]
[SIZE=6]I will check this weekend and see how things work out.[/SIZE]
You are welcome. Keep us posted.
MY WASHER WILL ADGITATE BUT NOT DRAIN OR SPIN, I CAN HEAR A NOISE THAT SOUNDS LIKE THE PUMP TRYING TO WORK, BUT NOTHING HAPPENS. IF I LET IT FOR A WHILE AND RESET IT OR UNPLUG OR EVEN RESTART THE CYCLE SOMETIMES IT WILL WORK FINE. I CAN MANUALLY DRAIN THE TUB BY LOWERING THE HOSE TO THE FLOOR, BUT IT STILL WONT SPIN. I AM WONDERING IF IT IS THE WATER LEVEL SWITCH?
