Refill Rinse Aid Light
My Refill Rinse Aid and Sanitized Lights have never worked from day one. The latter isn’t as big an issue because if 0 shows in the countdown window I know it’s done. I’ve also programmed it for extra drying and then prop open the door when done. That all works fine. However, when the dishes start coming out wet then I know it’s time to refill the rinse aid dispenser. But, in a unit this expensive is it too much to ask that the Refill Rinse Aid light work?
I’m trying to avoid a pricey service call if it’s a simple reprogramming that I could do myself.
Any suggestions?
Thanks,
Gary T.
