My fridge is freezing almost everything in it. I raised the temp control to 38 degrees in the fridge and 5 degrees in the freezer. It is still freezing. The average temp in the fridge is 30 degrees. The average temp in the freezer is 2 degrees. The freezer portion is working fine.
I am waiting for a replacement water filter that had been on backorder. I should have changed it about 4 weeks ago. Would this affect the temp?
Where should I start to try and figure out what is going on?
Thanks for your help!
