Water accumulates at the bottom of the inside of the refridgerator and then flows out to my kitchen floor. I looked all the way in the front bottom and I don’t see an evaporation pan. Do I need to take the fridge apart to get to a tube? Any help would be very appreciated. Thanks.
Most likely the problem is a clogged and/or frozen drain.
Remove the evaporator cover (#201 on the [break down diagram](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=547407&&model_id=206054"]break down diagram[/URL]) and look for the drain hole under the evaporator. Use a hair dryer and/or a turkey baster and hot water to defrost and clean it.
Check the drain hose (#315 on the [URL="http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=545050&&model_id=206054)).
Here are the break down diagrams for the Hotpoint refrigerator http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=545050&&model_id=206054
