Refridgerator will not cool and freezer wont freeze
We replaced the overload switch. Still not up to par. It is a little cooler but nothing like it should be. What else could we possibly replace? The commpressor kicks in fine and we cleaned the coils under the fridge. This is a top/bottom:( Please help!!
I could find no info on an adb2533deq.
Are you sure it is not a abd2533deq whose parts breakdown follows.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167305
There does seem to be a problem with the above as the wiring diagram at the end shows a manual temperature control while the parts show electronic.
Please confirm the model number and what typ of controls you have.
Which switch, the overload on the compressor or the defrost thermostat etc.?
Need more info as to what are the symptoms.
Is the compressor cycling?
Are there any strange noises?
You say it is too warm but what is too warm ? The freezer and/or the fresh food section?
Can you check with a thermometer, the temperature in the freezer and fresh food sections?
Freezer should be 0 to 5 degrees F, fresh food close to 40 degrees F.
Is the evaporator fan running?
Is the condenser/compressor fan running?
