Refridgerator won't cool
Neither the freezer or fridge will cool at all for my Roper unit. Light comes on and freezer fan runs. Heat from the non-running compressor will allow no more than 1 second of finger contact with compressor…kinda hot. If i unplug then plug in unit I will hear one click coming from the compressor relay. (only one click sometimes a second click with a 10 second intereval between) If it stays plugged in, a click every so often, but not rapid consecutive. Compessor relay is not visually burnt not does it smell burnt.
Compressor terminals continuity checks out OK as well as the test for compressor grounding.
Thoughts?
Thank You
Pry off the compressor side cover, note which wires went where, then replace the small, black ptc device AP3608944
