refrig & freezer both stopped
Both sides quit working. The fan is running and the compressor is running but nothing is cooling??
If the freezer is fan and condensing fan are running and the compressor is running, you have refrigeration problems for a pro to look at. You might pull off the back freezer panel and confirm either no frost or a little at the top.
