The refrigerator temp is within spec of about 38 to 40 deg, however, the freezer temp varies between 50 and +14 deg.The compressor seems to be running because of refrig temp but it does not seem to be running consistently when the freezer temp is in its hi temp range. I hear no relay clicking at random. What would cause this, the deep freeze control, other thermostat, or?
Related topics
Fluctuating temp for bottom freezer | 2 | 795 | August 26, 2013 | |
Freezer cold, refrig warm | 1 | 1767 | November 21, 2009 | |
Refridgerator temps hover below freezing on warmest setting | 1 | 1318 | January 1, 2012 | |
Cooling Issue | 5 | 955 | October 17, 2013 | |
refrierator | 1 | 814 | August 4, 2009 |
