I need to replace the water tank because it is leaking. It is up against the back wall behind the left fruit drawer. I got the replacement part from AppliancePartsPros but no instructions on installation. Mainly, I need to know if there is any procedure for cutting and splicing the hoses. I will want to take this tank out for the winter each year. The tank came without compression nuts but you are sending them to me. Should arrive tomorrow. Thanks for your advice.
