[LEFT][COLOR=#000000]compressor sound like it work and so is the evaporator fan and the condenser fan but not cooling or freezing at all, I am thinking that is in defrost all the time, but the compressor is runing, does the compressor runs when on defrost? any sugestions?
[/COLOR][/LEFT]
When your compresor is runing, its a good indicatioin that its not in the the defrost cycle … More than likely you have a bad compresor and or a leak somewhere in the sealed system … in both cases the whole refriderator should be replaced… your cost to fix sealed system will excede the value of the refridgerator
that’s what I tought, thank you for your help.
is it posible that the start capacitor divice not giving enough volts to the compressor? will the compressor partialy work with -10% volts?
