refrigerator and freezer not cold enough
both my refrigerator and freezer were not cooling at all, condensor fan motor, compressor, lights everything is running, coil was clean but I blew it out with compressed air anyway to be sure, both freezer and fridge were warm. I replaced the main PCB assembly and now the refrigerator cools and freezer is freezing but not cold enough and temperature inside doesn’t match temperature setting on door control panel. Refrigerator temperature is set at 33 degrees but inside is only 42 degrees. Freezer temperature is set at 0 degrees and its about 7 degrees inside. Any help at all will be very, very appreciated. Thank You
