The door hinge parts (bottom hinge assembly #2223520, and door closer upper cam #2182178)have been replaced by a different number (bottom is now 2307179, and top is 2182179), however, the new parts do not fit together properly so they cannot be used. Any suggestions for getting the original parts?
The manufacturer has redesigned these parts and changed the part numbers. There is no way you can find any of old parts because they have been replaced in all parts store.
Thank you. The only problem is that they don’t work. Puts me in a tough situation.
