Friends,
I have a Frigidaire, top freezer refrigerator which is just blowing room temperature air. I took the back panel off, took out the relay and the capacitor and tested them (continuity test for relay, ohm and voltage for capacitor) and they are working fine. I also tested out the thermostat and that seems to be working fine as well (continuity test).
The only thing left is the compressor. So I did the scratch test to see if it is shorted/ grounded inside and it is not.
Then I performed a continuity test on the bottom two prongs of the compressor, I get a value that bounces from 300 to 20 ohms and does not beep. The top and the bottom right prong gives a value and beeps.
Does this mean the compressor is bad?
Also when I shook the relay it sometimes rattles but not constantly. It beeps for continuity test on all three inlets.
Any help will be much appreciated. Thank you
Oh by the way, the coils are clean, all the fans working, door seal is fine, the light inside the unit is working as well.
