Refrigerator Side Warm
evaporator motor stop working, i replace the motor but the new motor only work for a second and stop and continue like that, i notice there is not enough air going through the duct to the refrigerator side.
How i test the evaporator motor to see if there is something else wrong with the refrigerator.
Check the voltage going to the fan. Should be 120. Problem may be adaptive defrost control part 23(f23) on diagram 2. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153542
the voltage going to the fan is 120 but is intermittent coming and going every two second.
how do i test the adaptive defrost control
I do not know how to test them. Sometimes you can see a burnt, discolored or corroded area that’s bad.
thanks a lot. I order the adaptive defrost control part 23(f23) on diagram 2. Replacement parts for FRG FRS26BH6CB4 | AppliancePartsPros.com. Replace it,and the refrigerator is working fine, thank a lot again.
