I had a defrost problem and replaced the main control under the freezer cabinet and the defrost thermostat. After installing the new control and thermostat, I put a thermometer in the freezer and one in the refrigerator. The digital display in the refrigerator reads 0 degrees in the freezer and the thermometer reads 0 degrees. However the digital display in the refrigerator reads 37 degrees in the refrigerator and the thermometer reads 42 degrees. I have switched the thermometers and get the same readings. Any suggestions as to what the problem is? Thank you.
Related topics
refrigerator too cold | 1 | 561 | January 13, 2016 | |
Frigidaire Gallery Freezer incorrect temp reading | 1 | 2844 | March 5, 2015 | |
Temperature control showing 45 deg for both frig and freezer | 1 | 486 | June 10, 2015 | |
Temperature sensor faulty ? | 2 | 1462 | July 27, 2013 | |
Frigidaire Gallery display say 47, but fridge is freezing | 1 | 479 | August 18, 2019 |
