Refrigirator water dispenser not working
The water dispenser stopped working. Before it always made a click noise when i press the button for water and another click when i release the button. Now it no longer make the click sound and no water comes out. It seems a valve no longer opens or a slenoid is not kicking in. I have replaces the water fitter. Where do I start:confused:
The problem can be a bad dispenser control board or a bad solenoid. Perform the troubleshooting as instructed in the Service manual and post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171426&diagram_id=1340368
I received the part but how do I remove the in and oulet lines from the unit. It seems they just slide in, how do I get them out without cutting them?
To disconnect the tube, push in the white or blue collar on the quick connector and pull the tube out.
— Begin quote from Gene;228762
The refrigirator is up and pumping water again - thanks for your help
the refrigirator is up and pumping water again - thanks for all the help
You are welcome. I’m glad you were able to fix it.
