Regular knocking noise on spin cycle
Hi I have a washer that is making a regular knocking noise on the spin cycle. It is spinning fine, not hitting the sides, so it is not an unbalanced load. It does not sound like a grinding or screeching noise. It is a a well timed knock knock knock knock sound.
So far I’ve found it could be the tub bearings or the clutch assembly, but I’m not positive. Any advice would be greatly appreciated. Thanks!
Also, additional information it only seems to happen when the motor kicks in. Once the motor stops, even when its spinning the knocking stops.
