I would like to know where to plug the power wire into the relay, sine it has three holes in your diagram.
What is exactly wrong with your refrigerator?
Why do you think you need this part?
Did you order it? If you did then have you received it yet?
Did you install the start device identical to the AP3210331? If so, your fridg wires should fit right into the new start device.
Thank you for your response. I forgot to check the locations of the wires before pulling off the original relay. I really appreciate if you can help me to locate the wires.
Thank you for your response. The compressor was clicking on and off. I pulled the relay off and heard some broken parts moving inside, later put it back and the refrigerator worked for six hours then the same thing happened again. when I removed the relay, one wire got loosen. After I completely removed the relay, compared it with the diagram and ordered it, then I realized that I forgot to locate the wires. I really appreciate if you can help me to plug the wires into right places.
