Remove inner door and door gaskets
Hi all,
I need to replace the door gasket for my refrigerator and in checking all of the posts, it is indicated that you fold gasket back and expose screws that have to be removed. This model does not have any exposed screws that hold the gasket or inner door on. Any advice on how to get the door seal off. Thanks in advance
If there are no screws then its a tongue and groove. Look at your new gasket to determine this. If thats the case, just pull outward on the gasket and it will pop right off. Just push the new gasket into place. Make sure you warm up the new gasket before installing it. This will make it more plyable. Just toss it in the dryer for about 5 minutes before you install it.
[http://www.appliancerepair-shiawassee.com](http://www.upthemileage.com/"]http://www.upthemileage.com[/URL]
[URL="http://www.appliancerepair-shiawassee.com/)
