I’m about to replace the flapper door, spring, and crank on a GE GSS25XSRASS Fridge/Freezer and would like some insight on how to go about it without destroying anything.
My first obstacle is how to remove the front bezel. Once I get past that, I assume the rest will be pretty straightforward.
Does it just pop off, does it slide, or is there some other removal trick?
Thanks,
Roger
