removing plactic cover to replace control module
I want to replace the control modure in my Bosch dishwasher SHU 5300.
How do I remove the plastic cover on the DW door to get to the module?
If you are talking about the fascia panel then you can find the instructions attached to the reply. If you need the correct part number for the control module then verify and repost the model number. The model number you posted is incomplete. You can find it on the right side of the door.
