Removing Pump Filter
I can’t find the service manual that shows how to remove this part. It needs cleaning as scale has built up even with cleaner solutions. I have everything removed down to that one piece and can’t see anything that holds it down.
Hi.
Follow this directions:
Remove racks. Remove Wash Manifold Loosen Wash Arm Hub and Pivot. Remove Spray Arm. Remove 3 Torx™ screws securing Filter Guard.[LEFT][COLOR=#000000]
Read more: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-filter-plt-item-number-ap4429782.aspx#ixzz1sWh4i7p8
[/COLOR][/LEFT]
Thank you.
Simon.
I got the answer as I used a brush and found both screws… sorry for bothering you with this. Thanks for always helping with these matters.
You are very welcome.
Simon.
