removing range to to access boards
My bake function stopped working after a power failure and I need to access the main board to replace. I cannot figure out how to lift the range top. Do I need to unscrew/remove retaining nut on each of the gas venturis to allow the top to lift. I have removed the front trim and can see the clips but they are not holding it . Any help for a rookie would be appreciated.
