Removing tub from Frigidaire
Trying to take my tub out of the washer - got to this section in the directions:
The Spin Basket:
Using a 1/2 " socket remove the 5 bolts holding the spin basket to the trunnion. Lift the basket out.
~ "Well I hear ya, but it ain’t happening"
I think there is more holding the tub in place. I dug out all the debris around the tub base and tried to pull it out but the entire tub and motor move as one still- very heavy. Doing something wrong.
What else do i neet to do to get the tub out? The 5 srews are removed. I also took the 2 screws away from the trunnion piece holding the lockplate to the agitator.
The basket is two walls, an outer and an inner with what seems to be a cap around the entire two baskets. does that need to come off first in order to remove the inner backet or is the whole inner and outer basket 1 assembly with ring cap included?
I am trying to fix a leak with part number AP2142342
Thanks,
:slight_smile:
