My refrigerator (GE Model TBX19JASNRAD) has started to have a build up of water right under the vegetable and fruit bins. Is there something that I need to do or correct this? A couple of friends say that the refrigerator is about to stop working? Is there anything I can do to save my refrigerator?
Thank you very much!!
RJennings
jenningsr8@hotmail.com
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it’s stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
I ordered (order # 1122134) and received part AP4100487, also called WPL74011278, to replace the oven light receptacle in my Jenn-Air model # SVE47100B. The original receptacle in my oven uses a common-looking light bulb. The new one does not and the "bulb" is nothing I’ve ever seen before. Here are my questions:
- Is this really the right replacement part?
- The light cover does not seem to be removeable. Should it be? If so, how is it removed? If not, when the "bulb" burns out will I have to replace the whole part again? (The cover on the original screws off to get to the bulb.)
- If this really is the correct replacement part how do I go about getting the old one out and the new one in? (The part did not come with any instructions.)
Thank you!
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
