replace dryer hinges
How do I gain access to the springs on the hinges? My son leaned on the door and now it closes, but will not stay closed:confused:
Take out the lint screen and you will see two screws. Take them out. You can now pop the top open by carefully inserting a screw driver at the edges in the gap between the top and the front.
You can now take off the front by disconnecting the door switch (note how it goes so you can get it back on) and by taking out the two screws on each side that hold the front to the cabinet. Lift is off the support pieces that hold it at the bottom and there you are.
Thanks! That was the answer I swas waiting for.
