I have a Whirlpool LE5720XSWO. The dryer started taking longer and longer to dry a load, then finally quit heating altogether.
I replaced the heating element yesterday, turned the dryer on and it heated up, no problem. Today I dried a load of clothes, and at the end of drying, the dryer was incredibly hot and the clothes were too hot to touch.
I have read that the problem is probably the thermostat, but when looking at your parts list, #6 on the diagram is listed as the Cycling Thermostat; #7 and #15 are listed as the Thermal Cut-off and High Limit Thermostat. In this scenario, which thermostat most likely needs to be replaced, the Cycling Thermostat or the High Limit Thermostat? If I have to replace both, can I just order Item #6 and Item #15, the t-stats only, and skip Item #7, the Thermal Cut-off?
Please advise, thanks so much!
