replaced,replaced,replaced....
PUMP STOPPED I REPLACED IT…STILL WOULDNT PUMP…REMOVED DRAIN LINE FROM BOTTOM OF TANK… REMOVED A SOCK…PUMP STARTED WORKING…STARTED SMELLING BURNT RUBBER AND HEARING A HOWL…COULD PUSH MOTOR IN A LITTLE…STOPPED THE HOWL…BELTS BURNT UP …MOTOR IS VERY HOT… NOT SPINNING ON SPIN CYCLE… PUMPING THOUGH…REPLACED BELTS…EVERYTHING TRACKING WELL… NEW BELTS BURNING UP… FIRST RUN…THE MOTOR IS HOT HOT …STILL NO SPIN… ANY CLUE?:confused:
