I want to replace the belt in my dryer but cannot find a repair manual. I need to know how to open the box to gain access to the area. The motors turns, dryer heat is on, but the drum won’t turn. Exhaust hose is clean. Noises normal. Any help would be appreciated.
There are 2 clips between the top and front panel which are about 2 inches in from the corners. Use a putty knife (or similar tool) to release the clips then pull the top forward a little and raise it up.
From here you should be able to pull the front panel up out of the way, make sure you disconnect the door switch!
Then you can replace your belt.
Hope that helps
Nat
