Model number is: PFS22MISBB
I’m replacing the Frame Lower Panel of a GE Free-Standing French Door Bottom-Freezer Refrigerator due to busted side rails supporting the underlying crispers.
I received the new part. However, I have to remove key items from the old part including the plastic center support and a metal subframe component.
What is the "trick" to remove this center support. It has a "pin" that goes through the back with a snap-in type fitting without external controls, etc.
Thanks a bunch.
Sven
