The agitator on my washer has gotten sluggish, with heavy loads it doesn’t want to work at all. I removed the back cover, and sure enough the belt has gotten worn and loose. I am going to replace the belt, but the video does not look the same as my washer. The belt is above the motor. It looks like on my washer I can just undo the clamp that holds the coupling to the pump and slip the new belt through that opening. What I am wondering is if I need to loosen the motor in order to (1) get the new belt on and (2) tighten the belt. I cannot tell if there is any ability of the motor to slide so that the belt would be loosened or tightened. Thanks for any help you can give me.
Related topics
GE washer wont spin belt appears loose | 1 | 5168 | June 19, 2008 | |
Belt installation | 1 | 922 | April 3, 2009 | |
Changing Drive belts | 1 | 981 | October 15, 2008 | |
GE Washer Agitator Needs Repaired | 1 | 1011 | June 19, 2009 | |
Washer agitator | 1 | 856 | August 5, 2009 |
