Replacing Clutch in Maytag Top loader
I need to replace the clutch and believe the cabinet needs to be removed to do this. Is there a step by step guide to accomplish this task?
— Begin quote from greeneye;267028
Green eye,
Yes, the cabinet does need to be removed to repalce the clutch brake assembly.
Here’s a pretty good process / procedure primer :
Clutch Replacement on Whirlpool and Kenmore Washers
I think this will get you through the process.
And here’s the part number for the clutch kit
[part]AP3094537[/part]
Good Luck,
:cool: :cool: :cool:
