I am fixing to change the clutch on my washer. I have had the tranny and shaft slid out ton check for sticking brakes. Found them working fine. Just wandering how easy it is to just change clutch assembly. thanks for any help!
Easiest thing in the world. Just use pliers to squeeze the clutch lining and it will come out, and you can then put in the new lining the same way.
