Replacing Ge Heating Element
the heating element went bad again im on my second one now.i saw online to replace it with the newer dual element. i did. the freezer gets cold enough now but when the element comes on the temp drops too much. freezer goes to 14 degrees sometimes and ice cream gets soft.does it drop temperature too much because the dual element
heater stays on too long? do i need to just get the single stock one and forget the dual design? also the steel panel has been off while testing the new heater, will the panel being off cause the temp to get too high? any help from a pro is greatly appeiciated
