Replacing inside door glass
The inside door glass broke on the oven door when self-cleaning. I have looked at the glass replacement parts. They are linked by serial numbers. Mine begins with 33C137. Need help with the correct part to order. Also, since the glass broke while using the self cleaner should any seals or other parts be replace to avoid it happening again?
Thank you for your help.
