lower spray arm needs replacing. got a replacement and bearing ring. looks like the spray arm connects to the outlet via a shaft through the center. is this shaft a separate part, can’t find it on the diagram? or is it the nylon radial bearing ring shown on the diagram?
Just remove the plastic nut holding the spray arm in, and replace spray arm.
