I have a Kenmore washer model 11027082601 and would like to replace the noisy bearings in the tub. I would like to know the part numbers of the bearings and seals. It would be alot cheaper than buying the whole tub assembly.
I don’t think you will find factory part number for just the bearings.
You could try to remove them and match them up with a place that sells bearings.
Other wise it’s going to be a tub replacement.
