replacing oven control panel
I need to replace the control panel on the above. Will I need to cut off the gas and electric or just unplug the wires from the damaged unit and
plug them into the new unit and remount?
Here are the parts
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=pgr5715bdw
This should help
http://www.servicematters.com/maytag_library/docs/16010161.pdf
Definitely unplug the unit or you may need another board.
Not sure about the gas.
