Right front burner won't turn on
My right front burner stopped working today. All of the other burners are working fine. The burner is the dual element one. I read an earlier thread about a similar issue with this model but the difference is that my indicator light for a hot burner doesn’t come on and neither does the indicator light at the switch. I hear it click when I turn the knob but nothing happens.
I use this burner all the time. Help!
Thanks,
Les
— Begin quote from lskjperkins;383460
Thanks,
Les
Les,
We can presume you may have a broken wire to the front right switch or a bad switch itself, based on the statement that all the other burners work.
If you concentrate on the first page of this Repair Forum post, you’ll have all the access and test information, for repairing your unit, including voltage checks at the burner element.
I’m sure you’ll be able to handle it from there,
Good Luck,
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/118185-jenn-air-electric-range-right-front-element-fails-hot-indicator-lamp-stays.html
Thanks,
Les
Les,
Based on your post, we can presume you have, a bad infinite switch, or broken wire to the custom control or right front burner.
If you concentrate on the first page of this post, you’ll be tested and operating in no time.
Good Luck,
