I can hear the timer on my dryer ticking but I can’t get it to run. I also hear a low humming near the power button. HELP!!! I cleaned out the hose in the back. What else can I do?
Check your door switch with an ohm meter, check it for continuity.
here’s your parts breakdown http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246775
Nat
Whats a ohm meter? I held the door switch down and pressed the on button at the same time and nothing is working but the timer.
Without the appropriate tools you’ll probably need to call in a technician.
Nat
