My machine is 2 years old. I did about 5 loads yesterday and the last one didn’t drain. It went through all of the cycles, just didn’t drain. Today I put it back on the spin cycle to drain & the motor starts making a whirring noise, if that makes sense. What could be the problem?
Check the drain pump () located on the front of the motor and see if something might have found it’s way in and is now preventing water from leaving the tub. The easiest way to get to the pump is to remove the screws holding the control panel is place, then remove the two gold colored clips that hold the cabinet to the rear panel. Take hold of the inside of the opening and tilt the entire cabinet toward you and off the base. The pump is in the middle at the bottom.
Thank you. There was a baby sock in it.
Those little buggers can get away from you. Glad I could help.
A model number would help in troubleshooting this as we may be able to find a wiring diagram.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit’s terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 15 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
