My Roper washing machine stopped working after filling with water. It had worked fine with the previous load. After it stopped I tried moving to the rinse and spin cycle but these cycles would not work either. There was no noise coming from the machine, it just simply would not work. We did notice a smell of grease or burnt rubber. We checked the lid switch and that did not solve the problem. We have also replaced the drain pump within the last year as well as the motor coupler a few months ago. After leaving the washer sitting for a while it will work normally for a load but during use and immediately after the washer emits a strong smell of grease. We would like to repair this washer if possible rather than purchasing a new one but are not sure where to start or what the problem could be. Can anyone offer any advise with this problem?
Related topics
Roper Washing Machine, No cycles work, Not draining | 1 | 3586 | May 5, 2012 | |
Need washer help - Roper | 2 | 1091 | June 2, 2010 | |
Roper washer fills with water then nothing else | 2 | 699 | May 18, 2016 | |
Roper washer fills with water then nothing else | 1 | 558 | May 14, 2016 | |
washing machine | 0 | 878 | September 17, 2011 |
