Roper washing machine stuck in spin cycle
I found my washing machine stuck in the spin cycle. I can only advance the cycle manually. I’m assuming that the timer is bad. How do I test the timer?
Did it get cold water for the rinse cycle?
Did it always stop at the same point?
If the both answers are "yes" - the timer has to be replaced.
Here are the break down diagrams for the Roper washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=4775&&model_id=234934
