Roper will not spin or drain
I have an old Roper washer that stops completely before spinning or draining. It does not make any sounds, and it will not spin/drain on any cycle. What is the most likely problem with this washer?
Thanks,
Nathan
Hi.
You will need to replace the lid switch.
Use the video clip for the instructions.
The lid switch 3949247
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=263575
Thank you. Post the results.
Simon.
