Runs for a day then stops, can restart for day
Came home to a warm refrig and freezer with everything thawed. Turned temp control (located in freezer) to Off then back on and it started again but did not run long. After searching it appeared the defrost timer and / or defrost thermostat might be the problem so I replaced both for less then $25. It started, ran for about a day and got cold enough to keep ice frozen in a cup in the freezer. The next day the ice was thawed and both refrig and freezer were warm again. Turning the freezer temp control off then back on made it start again. It appears to me that something is now stopping it from restarting after a defrost cycle. What would be my next parts to check, Temperature Control (AP2145312)? Temperature Sensor Housing (AP2148604)?, Relay and Overload Kit (AP2585033)?, Run Capacitor (AP2115490)? or ???
Thanks in advance.
