Runs full cylce on Delicate. Fills with water on on other 2 settings then times through cycle to the end not agitating or spinning out the water. Can go back and run spin on perma press cycle. Any suggestions.
Thanks.
If it does not make any noises at that time, most likely the problem is a bad timer.
- The timer AP4026344
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=42100
